Work continues on the 1655
Shep
02-14-2003 05:22:11
Finally downloaded some more pictures of the progress of the 1655/Cummins that I am working on. It is coming along nicely, the engine is in and set and the radiator is on, and I am hoping to have it to where it will start in a few weeks. If it snows like the weather guessers are screamin about I may be pushin snow all weekend instead of workin on the tractor. Take a look if you want, heres the link...
mike jacobs
02-15-2003 12:47:43
 Re: Work continues on the 1655 in reply to Shep, 02-14-2003 05:22:11
I was wondering what you were paying for the cummins engines you had bought. We have an 1800 oliver diesel at home and we put in a new head gasket and we got it back together and used it for corn chopping and now the thing is making noise in the engine some where. We would like to repower it with a cummins repower but they are too high priced. We also looked into other options like a detroit diesel that we found for $1200.
Shep
02-15-2003 16:31:56
 Re: Re: Work continues on the 1655 in reply to mike jacobs, 02-15-2003 12:47:43
Yeah, everyone always says the Cummins engines are too high and the conversions cost more than the tractors are worth, and then I have seen guys dump more into a 310 Waukesha in a few years than I have in my conversion, and I didnt have all the down time. It does cost more up front to do a Cummins repower, but I am hoping to not have to touch that Cummins power plant for at least 10,000 hrs other than regular maintence. I now have the first 1000 hrs on one of my Cummins machines with no problems, and that is better than the 310 could do before I changed it out.
I can normally get engines for $4,000 to $5000 for the engine and another $1,500 to $2000 in conversion parts. If you repaint the tractor or do other things while it is down it can cost more but normally well worth it. I will have around $8,000 total in my 1655 when I am done (I hope), including the purchase of the blown up tractor. For a 100Hp oliver tractor with a used Cummins engine, 4 good tires and a new paint job, I dont think that is bad. And the good part is I should not have any major problems with this tractor for a long time.
mike jacobs
02-16-2003 20:40:01
 Re: Re: Re: Work continues on the 1655 in reply to Shep, 02-15-2003 16:31:56
We live in minnesota. A cummins repower from cummins in fargo nd runs any where from $5,000 to 6,000. but that includes all parts you need to do it with.
Shep
02-17-2003 16:24:21
 Re: Re: Re: Re: Work continues on the 1655 in reply to mike jacobs, 02-16-2003 20:40:01
Yeah, that sounds about right. In fact that is probably better than I am doing putting all the parts togeather myself, but I kinda like doing it.... Is that for a new engine????
mike jacobs
02-18-2003 06:37:14
 Re: Re: Re: Re: Re: Work continues on the 1655 in reply to Shep, 02-17-2003 16:24:21
Yes it is a brand new crate motor. You got your choice between two engines. They are both 4 cylinder diesels. One is 95 hp with no turbo and the other one is 120 hp with a turbo. I think for the money a person spends, the 6 cylinder is a better motor in the long run. For the same hp as the one 4 cyl with a turbo.
Skinner
02-14-2003 17:57:35
When GEO shuts you down for going over your allocated bandwith they do it in a snap. I was just on there looking around and wham "not available". Guess I'll wait till in the morning. I'm kind of anxious to see your progress. Always look forward to checking out your projects.
Shep
02-15-2003 16:24:27
 Re: Re: Work continues on the 1655 in reply to Skinner, 02-14-2003 17:57:35
Yeah, I have been working on a page before and the bandwidth gets exceded and WHAM im am off from workin on things. I guess i could pay a few bucks a month and keep her running all the time, but I would rather spend my money on tractors and parts. Thanks for being patient.
dwm
02-14-2003 09:02:41
A lot of work, but that will be a sharp looking 1655 when you're done. Should also be pretty stout. Would have to start better in the cold than the 1655 D I had years ago--no where to go but up on that one! Good luck. dwm
