Oliver/Hart Parr info wanted
Bill Smith
02-12-2003 21:28:31
Seen a tractor sell at auction about a decade ago. It was a 4 cylinder unstyled tricycle row crop on steel wheel's with fenders, crank start, and just guessing about the size of a 70 or a little smaller. I am fairly certain that it had the exposed caste iron framed radiator as did most unstyled tractors but with Hart Parr casted in the top front of the caste iron of radiator. This tractor was fairly complete but had froze engine and really needed alot of work to of been restored. It still managed to bring alot more than I expected. Can't remember how much it brought, but it was like $2000 or in that ball park. Always wanted a tractor like this one but haven't seen one like it since. I guess my questions are 1. Any idea as to what the actual model of this tractor was? 2. Was Hart Parr casted into the unstyled radiators after the 29 merger? 3. How rare are these Hart Parr or Oliver Hart Parr tractors and how hard are they to find and get parts for if one was restoring? Always been a Farmall man but my real antique tractor dream was to have a Hart Parr like the one I seen sell years ago. Any info would be appreciated. Didn't find much help veiwing the forum photos. The closest thing I seen like it was the unstyled Oliver Hart Parr 70 on steel. The radiator that I remembered was different than that of the 70 photo. Thanx in advance.
UK Row Crop
02-16-2003 06:19:51
 Re: Oliver/Hart Parr info wanted in reply to Bill Smith, 02-12-2003 21:28:31
Bill, Look through photos at olivergang.org there are some 18-27 pictures on there.
Bill Smith (thanx you guys)
02-16-2003 12:25:05
 Re: Re: Oliver/Hart Parr info wanted in reply to UK Row Crop, 02-16-2003 06:19:51
Thanx UK. I went there and took a gander at the photos. Seen a couple of single fronts and were good photos. Never seen a single front in person so I now understand better of how the single fronts were. I don't believe I ran across any 2 wheeled front end photos. But that's O.K. From what I remember they were alot like the front end on the 70. Don't think I am real sold on the single front style even though they are maybe more rare and unique. I like the looks of that slanted dual wheeled front end alot better. That slanted forward design I think looks really neat having the front wheel's sticking out in front of tractor a bit. I like that alot better than the way that single front looks right underneath of the radiator. I believe I will be keeping an eye out for one and hopefully someday I will be on here seeking info on parts and restoration tips. James has one with single front for sale but quit aways away. Nothing against his tractor but I believe I will hold out and see if I can find a dual front for sale and closer to home.
James Tierney
02-13-2003 19:12:53
I have an 18-27 single front tractor like you described. It was built in 1930, and is unrestored, but running and fairly complete. The parts that are missing are all on a seperate 18/27 parts tractor I've found. This tractor is unique, in that it has a factory rubber front wheel and factory add-on rear band brakes (originally, it came with only a parking brake). The rear has cut down wheels with very good tires. I am trying to get steel rears for it as well. If you are interested in a tractor like this, I would consider selling it with any parts you want from the parts tractor.
Thanks,
James (920)206-9003
UK Row Crop
02-14-2003 12:59:58
 Re: Re: Oliver/Hart Parr info wanted in reply to James Tierney, 02-13-2003 19:12:53
I thought the turning brakes were standard on all 18-27's. Were the brakes on dual front 18-27's the same as the 1930 built tractors, apart from the self braking rods from the steering??
James Tierney
02-14-2003 16:12:32
 Re: Re: Re: Oliver/Hart Parr info wanted in reply to UK Row Crop, 02-14-2003 12:59:58
The early 18/27's with single front wheel did not have brakes on the pinions like later tractors, and the diffential was on the axle, like an 18/28. I believe Oliver upfitted many of the early 18/27's with band brakes on the axles. That is the way my tractor is set up.
thanks,
James
Bill Smith
02-13-2003 21:51:06
I would very much be interested. I understand the single front is somewhat rarer than the 2 wheel tricycle front. What type front end does the parts tractor have? If I was going to sink some extra cash in the wheels I would rather have the less common (hopefully cheaper) 2 wheel tricycle front and put the extra money towards the steel wheel's. But that's putting the cart before the horse, I need to get a tractor first. Where are you located? What is your asking price? How much less would that be with the 2 wheeled front end if you have one instead of the single? If parts tractor is for sell as well, how stripped is it, and how much for that?
James Tierney
02-14-2003 05:55:47
 Re: Re: Re: Oliver/Hart Parr info wanted in reply to Bill Smith, 02-13-2003 21:51:06
Hi Bill,
The single front wheel 18/27's built in 1930 and 1931 have a unique frame that only allows the single front wheel to be used. The front wheel is directly under the radiator. Later tractors had a frame with a removable front end. The tractor I have has actually had a later front end welded to in, which I am carefully cutting/grinding off. There is no damage to the frame casting, and the yoke, bearings etc are all intact. I am interested in selling the complete tractor and parts tractor only, and am looking for $2800 for the pair. If I find steel for it, I would pass on the information to you. If you are interested, call me, and I will give you a complete description and send pictures.
Thanks,
James
(920)206-9003
Bill Smith
02-14-2003 11:24:54
 Re: Re: Re: Re: Oliver/Hart Parr info wanted in reply to James Tierney, 02-14-2003 05:55:47
Thanx for the info on the front ends and posting your price. Very useful info. I take your word and trust you on your description of tractor. I never buy tractors sight unseen and most people don't unless they are dirt cheap. My biggest thing is location. I am in Kansas. I know, pretty centrally located to do some traveling within country, but still at the same token, only willing to travel so far. Can you tell me what state you are from so I can get an idea of how far away you are? That would perhaps tell me ya or na whether I would be interested enough to come look and or buy. If I find your general location close enough perhaps I could call to seek further information.
James Tierney
02-14-2003 16:15:50
 Re: Re: Re: Re: Re: Oliver/Hart Parr info wanted in reply to Bill Smith, 02-14-2003 11:24:54
I am in Wisconsin, Bill, so there is certainly a drive involved. If you are interested, keep in touch - will mail pictures if you would like.
Thanks,
James
Larry
02-14-2003 17:30:01
 Re: Re: Re: Re: Re: Re: Oliver/Hart Parr info wanted in reply to James Tierney, 02-14-2003 16:15:50
Hi James I also have a 18-27 with a single front wheel. I would like to have one to restore. Are the two you have complete enough to restore one? The one I have has steel on the rear and rubber on the front. I would like to take a before & after to the shows. What part of Wisconsin do you live in.
James Tierney
02-16-2003 18:22:18
 Re: Re: Re: Re: Re: Re: Re: Oliver/Hart Parr info wanted in reply to Larry, 02-14-2003 17:30:01
I live between Madison and Milwaukee on Hwy 94. Is your tractor good enough to restore? Between the two that I have, there is enough, with the exception of rear steel, and a manifold, to make a fairly complete and original tractor. I would be interested in selling mine, or possibly buying yours for the steel, if it is too rough to restore.
Larry
02-18-2003 03:53:12
 Re: Re: Re: Re: Re: Re: Re: Re: Oliver/Hart Parr info wanted in reply to James Tierney, 02-16-2003 18:22:18
I have everything to restore mine and may restore it this year. The serial # is 100157, want to keep it as much origional as possible. Would really like to find a front steel wheel, that would set it of about right. If you or anybody knows of one, I could get interested. Thanks.
James Tierney
02-16-2003 18:21:32
James Tierney
02-16-2003 18:13:18
I live between Madison and Milwaukee on Hwy 94. Is your tractor good enough to restore? Between the two that I have, there is enough, with the exception of rear steel, and a manifold, to make a fairly complete and original tractor. I would be interested in selling mine, or possibly buying yours for the steel.
Lee W
02-12-2003 23:01:06
The tractor you are talking about is probably a 18-27, it is the forerunner of the Model 80. The Hart-Parr name was dropped in late 37 or 38 when the first 80's came out. The early 18-27 or row crop as they were called, with the single front wheel are the most rare of this model. I have been able to find parts for the one we have, usually from another parts tractor.
UK Row Crop
02-13-2003 04:09:38
 Re: Re: Oliver/Hart Parr info wanted in reply to Lee W, 02-12-2003 23:01:06
Most of the parts I needed for mine came off an 80, I have a parts book for the 80 and 18-27, so I can see what can be used on both tractors, most parts are the same.
