Super 55 Tranny
Rich
02-11-2003 15:47:38
When the tractor is cold and I let the clutch out (trans in neutral) the motor can hardly turn the tranny over, and the tractor tries to roll ahead. After using the tractor for 30 minutes, problem diminishes, but does not completely go away. I suspect that the gear lube may very thick, and it may need changed, any other suggestions?
JD in da UP
02-14-2003 12:39:39
 Re: Super 55 Tranny in reply to Rich, 02-11-2003 15:47:38
How cold? Mine does that and I just put in new 85w90 last summer. It's been getting below zero here. If it was water and very much below freezing, you would just have a frozen transmission, or a cracked something. Cold oil is hard to move til it warms up a little. My little 5 speed Mitsubishi pickup does the same thing! Hope some of this helps.
Don
02-13-2003 03:16:59
check the gear shift boot, even the smallest crack can let in a lot of water. The vent does not permiet alot of evperation. Before I restored mine it sat outside uncovered for just 2 months I had about 5 galons of water in it,did not rain that much.
Canada Grant
02-12-2003 11:47:00
Drain and replace before you have an ice cube in the trany and tear out some gears!! Any good gear lube is going to be better than slush.
