770 Temp Gage
Paul A. Ramey
02-11-2003 14:09:14
I have a 770 diesel that has been converted to an alternator. My temp gage starts to move when the motor warms up and as soon as the temperature is above, about 165 degrees the gage is pegged at hot and stays there. I have changed the thermostat and the temp-sending unit in the block. The tractor is not over heating and runs fine.
Does any one have any idea why the temp gage pegs at hot? Is it looking for 6 volts and not 12 volts to make it work properly?
Paul in WI
Dick
02-11-2003 15:58:06
 Re: 770 Temp Gage in reply to Paul A. Ramey, 02-11-2003 14:09:14
Put in a voltege inline reducer from 12 volt to 6 volt can be bought at napa store for little money
Canada Grant
02-12-2003 12:03:51
 Re: Re: 770 Temp Gage in reply to Dick, 02-11-2003 15:58:06
770 / 880 were factory 12 volt. My shop manual is not here now but parts book doesn't show resistor?
Super99GM
02-12-2003 22:42:04
 Re: Re: Re: 770 Temp Gage in reply to Canada Grant, 02-12-2003 12:03:51
770 gauges work properly on 12 volt positive ground. Most alternators are negative ground. This could be your problem.
