Your loader will work much better if you get the hydraulics from the power beyond ports. I too hooked mine up from the remotes, against everyones advice. She did not perform very well. I moved it to the power beyond ports and it worked great. Here is the info. An External valve can be installed for operation of additional hydraulics. This valve must be of the "Open Center" type and will take priority over the other hydraulics. Remove the 1/2" plug from the front left corner of the hydraulic housing, after removing the 1/2 plug, install a 3/8 plug inside of that port (deep inside there are threads). Now install your pressure hose to your external valve in that same place you just removed the 1/2" plug(Front left corner). Now remove the plug at the top, rear, left corner. This will be the outlet of your external valve. Caution - An open center valve "must" be used. When not using an external valve, those two hoses should be tied together. Explanation, pump pressure leaves the filter, goes to the external valve, then the returns pressure goes back to operate the rest of the hydraulics. Real simple to do, works well, however the ports aren't in the best place for routing hoses, but you'll figure out how to route them. Hope this helps. May need a torch to heat the plugs slightly to get them out. Don't forget to remove the 3/8" plug if you do away with this system on go back to normal (if the need ever arises). Skinner
