880 vs. 770 sheet metal
Steve Merritt
02-06-2003 11:56:14
Are all the sheet metal parts interchangeable between a 770 and 880? I've noticed some 770 and 880 engine tins and rear tins have recessed areas where the stripe and oval decals (1958 models) are located and some don't. I suspect the recesses disappeared when the stripe and oval decal (like on a 1958 model) changed to a newer style. Is this correct? If so, what year did the recesses disappear on the 770's and 880's? Thanks.
B A Star
02-08-2003 21:09:07
 Re: 880 vs. 770 sheet metal in reply to Steve Merritt, 02-06-2003 11:56:14
Part numbers for all of the sheet metal for 770 & 880 is the same for early and late tractors with the exception of the hood. The change in sheet metal to eliminate the recess was made at S/N 112 251, which was in 1961. White Motor had purchased Oliver in 1960, The Keystone emblem was introduced to company personell in November of 1960 for the 61 selling season.
E J
02-08-2003 13:17:46
I disagree .Have a 770 with a 880 moter with 880 sheet metal and grill.
m kuhns
02-07-2003 18:31:52
THe sheetmetal between the 880's and 770's won't interchange. The hood on the 880 would be longer than the 770 by a few inches
