Oliver 88 deisle to OC6
farm living
02-05-2003 09:08:12
In a previous message I was informed an OC6 is the same as a 77. I am curous to know if I would be able to pull out the 77 engine and put in an 88 deisle. Can anyone tell me if this would be possible or would I have to make to many modification to get it to work. Thanks for any help...
Terry
02-05-2003 15:47:42
 Re: oliver 88 deisle to OC6 in reply to farm living, 02-05-2003 09:08:12
I have never seen one done that way, but putting the 88 motor in the )C-6 shouldn't be any different than putting the 88 engine in a 77. Not that difficult of a swap. Why not put in a 77 diesel, if that is the goal, and keep it original? Terry.
IanC
02-05-2003 09:24:09
It would be possible, the same as putting an 88 into a 77 wheel tractor. The only hitch would be alinging the engine by shimming between the bathub, and the block. The OC's are much more picky about this than the wheel tractors. I had to change blocks in my OC-6 to replace a cracked one, and had to fabricate an alignment tool as shown in the OC-6 manual. Contact Landis Zimmerman to get the best advice.
