Super55: clearances on the battery tray
Francis
02-04-2003 09:38:54
Hello everyone,
I'm planning on replacing the battery on my super55.
The tractor is away and I dont have any idea of the maximum clearance (height) that the new battery should have in order to be able to pull the tray out without touching the side panels. The reason I'm asking is that I would like to purchase the new battery before I get onsite.
Thank you all
Francis
Francis
02-04-2003 19:32:44
 Re: Super55: clearances on the battery tray in reply to Francis, 02-04-2003 09:38:54
I forgot to mention that i'm looking for a battery with a high Cold Cranking Amps rating, because the poor old thing is living where it gets very cold in winter time. If i find out the clearance, i'll just go for the highest CCA that fit in.
Regards
Paul
02-05-2003 05:35:14
 Re: Re: Super55: clearances on the battery tray in reply to Francis, 02-04-2003 19:32:44
Just measured batteries at TSC and all their 6 volt batteries 9" wide 8 1/2" high and either 9 1/2", 12" or 15" long with 780, 935, and 1220 cranking amps and I wiil be going for the large battery as well because of the cold winters in Ontario. Hope this helps out.
Paul
Larry from MD.
02-04-2003 15:04:07
If its 12 volt a 22 or 24 battery works fine.If you want more room try 42 its 3/4 inch shorter and the same amps.
