1950 3pt.
john
02-03-2003 08:03:03
just got it, changed fluid in hyd.,the 3 pt goes down super slow with me standing on it can this be adjusted,thanks john
Terry Clubb
02-03-2003 16:48:19
 Re: 1950 3pt. in reply to john, 02-03-2003 08:03:03
John we have used the 1950s since they were new the 3pt lift was always slow to go down on them even with mounted implements on. It takes getting use to because they are as responsive as the 55 series& the Whites.Good luck Terry Clubb
Larry
02-04-2003 15:01:31
 Re: Re: 1950 3pt. in reply to Terry Clubb, 02-03-2003 16:48:19
I forgot the most important thing.The link that connects the valve and draft and position control can be installed upside down,and will cause slow lowering.It was so common that oliver sent out a service bulition on it.Its very easy to do wrong if you don't have a picture right infront of you.
john
02-05-2003 05:04:27
 Re: Re: Re: 1950 3pt. in reply to Larry, 02-04-2003 15:01:31
is this inside or outside,where is it? thanks
john
02-05-2003 11:13:38
 Re: Re: Re: Re: 1950 3pt. in reply to john , 02-05-2003 05:04:27
i had top cover off to put in o-rings on remote arms,could i of did this then,i do not think so do you thanks john
Larry
02-06-2003 09:26:15
 Re: Re: Re: Re: Re: 1950 3pt. in reply to john, 02-05-2003 11:13:38
If you only disconnect the one pin to the valve then its not your fault.I have seen people disconnect all three pins so they can slide things apart easyer,then you may get it put back wrong.
Larry
02-05-2003 10:18:02
Its under the top cover of the hydrolic unit and is connected to the spool inside.Its easy to find because it has 3 pins in it and connects position and draft control linkage and the valve.The hard part is figureing if its in correctly or not.When i worked on mine that had the linkage broken off I had to draw a diagram from the dealer service manuel to get it back correctly.The old meckanic made sure he told me the correct way this one piece went in.He said this is the piece everyone gets in up side down and their 3 point goes down real slow.
Larry from md.
02-03-2003 09:36:21
There is not a speed adjuster like the newer tractors have.The spool valve is under the top cover of the hydrolic unit.The lowering spool may not be opening all the way.I had a piece of grit stop one from moveing one time.Remove the seat and top cover and unbolt the valve,lots of orings seal it on the bottem.Then clean valve and make sure all the spools move fee.The other thing could be broken or miss adjusted draft control linkage.
