Oliver 60 rowcrop
JD Kid
02-01-2003 15:23:14
I have a Oliver 60 Row Crop and i need to find side curtins forit. I also need to find a engine rebuild kit for it. I do not know much about o
Olivers so any help on how to rebuild the motor would help. I am not sure if i gottta take the motor out in order to rebuild the motor.
havvey
02-03-2003 14:22:17
 Re: oliver 60 rowcrop in reply to JD Kid, 02-01-2003 15:23:14
try metgers for a rebuild kit there getting pricy and a little scarce that was a wakashaw engine 120 cubid inch i believe
Scott Green
02-01-2003 17:50:07
Hi JD Kid , One thing nice about the little "60" is that you can unbolt the engine , and manually tip it up out of the tub , and then turn the engine cross ways on top of the tub so that you can work on it. No crane or lifting rigs. I've had the engines out of 2 oliver "60" tractors , and that is how I had done it.
