Returning to Positive Ground
Mike B
02-01-2003 05:48:26
I am considering returning my 1959 Oliver 550 back to positive ground as part of a correct restoration. It seems rather simple, such as switching the poles on the coil, and reversing the polarity on the generator field. But the starter has me puzzled. Won't it run backwards?
Any and all tips and advice will be appreciated on dos and don'ts of switching back.
Thanks,
Mike
Bob M - forgot to mention
02-01-2003 08:38:27
 Re: Returning to Positive Ground in reply to Mike B, 02-01-2003 05:48:26
Mike - You don't switch any wiring at the generator! Just repolarize the generator after you've got the battery hooked up postive ground. (To repolarize, simply connect the regulator BAT and ARM terminals with a jumper wire for a moment - with the engine stopped...)
Bob M
02-01-2003 07:35:23
Mike - Don't concern yourself with the starter! It is polarity insensitive - will spin the right direction regardless of ground polarity.
You will need to swap the wires at the two ammeter terminals - otherwise it will read "backward" after you switch back to positive ground.
Super99
02-01-2003 21:46:22
 Re: Re: Returning to Positive Ground in reply to Bob M, 02-01-2003 07:35:23
Didn't think 550's had ampmeters.
