Briken rings
WAYNE IN PA
01-29-2003 15:03:36
Two years ago I baught a 2-70 with 6000 hours. It didn't start well on the lot, the salesman said it was not run for several months it had some blowby at the crank case vent. So this year I decided it was time for an overhal. When I got the pistons out all the top compreson rings were broken. By the size of the ridge in the slives it seams all the rings broke at about the same time. Does anybody have any ideas about what would brake the rings? Thanks.
IanC
01-29-2003 18:36:50
 Re: briken rings in reply to WAYNE IN PA, 01-29-2003 15:03:36
Excess ether usage (any ether is excess in my book) can do this also. I've seen this damage in engines which we knew for certian hadn't been apart yet, but had been ethered.
M kuhns
01-29-2003 17:27:45
THe timing could be advanced a little making it inject fuel too far before TDC. THis could easily break the rings too, as well as ring lands, and put holes in pistons.
Al m
01-29-2003 16:49:45
Maybe someone installed new rings in a worn bore and did not ridge ream the bore.The leading sharp edge of the new ring hits the radius of the ridge and breaks.My guess.
Al
wayne in pa
01-30-2003 14:13:10
 Re: Re: briken rings in reply to Al m, 01-29-2003 16:49:45
Thanks guys for the information.
It could be the ether but I dont think this engine was ever open befor.
