Oliver 55 Shifter and Seat Interferance
Rich
01-21-2003 17:31:09
When I sit on the seat (stock seat with good suspension) and put the shifter in right side of the shift pattern, I can't hardly get my leg over far enough to put my foot on the clutch. The easy solution might be to bend the shifter down and to the left, just wondering if any one else has this problem and what they did about it.
Pete in Ks
01-22-2003 05:22:15
 Re: Oliver 55 Shifter and Seat Interferance in reply to Rich, 01-21-2003 17:31:09
I don't have that problem on my 550. But I have my seat adjusted all the way back.
ShepFL
01-21-2003 20:27:55
For my 550 all I did was add some 4" springs to the bottom of my seat pan. I was to cheap to buy a new torsion spring. By adding the springs it gave me enough lift to shift my weight to the right when needing to shift into the higher gears. FWIW
