Hi Scott, You are very wise, indeed, to stay away from the urethane and enamel hardeners if you don't have a fresh air breathing system. Dulux was (is) DuPont's synthetic (alkyd) enamel that was used extensively years ago. Mark is correct. It is not used much at all anymore in the automotive refinish industry, which is now using the urethane chemistry almost exclusively. As a result, the problem you are likely to run into (guess you already have) is finding a local paint jobber that has the necessary mixing tints...just not enough call for that stuff anymore. On their website, DuPont claims that Dulux is still available for the fleet market. You probably could buy some directly from DuPont in 1000 gallon quantities :o). You might want to investigate a couple of alternatives that do not require isocyanate-containing additives. DuPont has an economy line of paints called NASON. In that line there is a product called FastDry. It is an acrylic enamel (w/o hardener) and should actually be better than the synthetic enamel, especially relative to improved fade resistance. Centari is also still available, at least in my area, mixed as a straight acrylic enamel that is usable w/o hardener. I don't think you can still get that in the tractor colors now that DuPont has the NASON line. It would also be more expensive than the FastDry. As far as I know, FastDry should be mixable in the tractor colors...it is for Allis Chalmers at least. Another potential alternative is PPG's OMNI line. OMNI MAE is a straight acrylic enamel w/o the need for a hardener that is available in the tractor colors. I purchased a quart of that last spring for my AC-B for $13 and change but didn't use it because I later decided to go with the urethane chemistry since I already have the fresh air breathing system. I believe that Martin Senour paints (NAPA) also has an economy line that likely includes at least an acrylic enamel that is usable w/o hardener but I am not at all familiar with their products. Rod
