Installing a block heater
Robert
01-13-2003 13:20:59
I bought a 1500W tank-type block heater for my 1650D. The instructions are pretty vague. Can anyone offer any pointers on where the block connections should be made. Should the lower connection be made at the lower radiator elbow which currently has a plug-in heater installed?
Shadetree
01-13-2003 15:24:16
 Re: Installing a block heater in reply to Robert, 01-13-2003 13:20:59
I have found that if you remove the rear drain cock from the engine block (found on the right hand side of the block). You can use a tee if you want to keep the drain cock useable, route the hose into the bottom of the heater. Route the top hose over to the heat gauge sending unit hole. Use a tee so that you can reinstall the sending unit. This will heat the engine block only which is what you want. I hope this helps, Good Luck Shadetree.
