Cockshutt 540 hubs
David Lynds
01-13-2003 09:33:49
Does anybody know of any manufacturers of after market Cockshutt parts in Canada or US? Specifically 540 hubs??
Phil Heisey-Harleysville, PA
01-13-2003 15:30:08
 Re: cockshutt 540 hubs in reply to David Lynds, 01-13-2003 09:33:49
I do not believe there are any aftermaket manufacturers of front or rear hubs for any Cockshutt built tractors. Do you need front or rear hubs? On the rear, the 58&59 models used an eight bolt hub. The 61&62 red belly models used a six bolt hub. I have used front and rear eight bolt hubs in stock.
Phil Heisey 215-256-8651 FAX 215-256-1203
Craig Embree
10-05-2004 20:30:04
 Re: Re: cockshutt 540 hubs in reply to Phil Heisey-Harleysville, PA, 01-13-2003 15:30:08
Hi Phil: I was wondering if you could help me with finding a part for my Cockshutt 540 hydraulic pump: I need the coupler and 16 tooth gear on the tractor side of the hydraulic pump connection found on the front right of the engine. I have the manual part # if that would be helpful. Please let me know, Craig
