Carbon
Mark
01-11-2003 06:26:35
What is a good product to disolve carbon build-up. I am cleaning up the some energy cells. Thanks
Shovelman
01-14-2003 18:33:45
 Re: carbon in reply to Mark, 01-11-2003 06:26:35
Mark,
Carburetor Cold Parts Cleaner is a dip-type solution that works great on carbon, however it is a bit pricey. The last time I checked, it was available at NAPA and came in a 2 gal. pail with a basket to put the parts in. About $35.-$40. Be advised, it is very nasty to work with. Be sure to wear hand and eye protection when working with it.
I have heard that soaking the parts in a strong solution of Lestoil and hot water works also, but I have never tried it.
Good Luck. Scott
Mark
01-15-2003 15:17:06
 Re: Re: carbon in reply to Shovelman, 01-14-2003 18:33:45
Since I didn't get a response right away, I asked my son. He said to use carb cleaner. Then I remembered the dip and soak type of carb cleaner we used years ago. I found product at Fleet/Farm over the week-end, but at $13 or $14 a gallon, I have my reservations as to the performance. It came with a strainer basket in the can and I'm dropping the parts in tonight. I'll let you know how it works though, and thanks for the advise!
Shovelman
01-17-2003 04:28:47
 Re: Re: Re: carbon in reply to Mark, 01-15-2003 15:17:06
I went to the NAPA store yesterday to pick up some parts, so I checked on the carb cleaner. They had a 1 gal. can (no basket) for $19. and a 5 gal. pail w/basket for $89.
I did not ask them if they could still get the 2 gal. size.
The stuff you bought will probably work fine. I find NAPA's prices to be high anyway.
Another alternative is to have the parts hot-tanked. Any auto machine shop/engine rebuilder should be able to do it for minimal $$.
However, be advised that hot tanking is caustic and will sometimes attack aluminum and lead/babbit parts.
