1600 throw out bearing
Larry
01-09-2003 09:35:46
Can you still get the bearing that takes grease from the inside.All the companys are selling a 1087 that greases from the outside, which I can't do on this tractor.I have called the oliver dealer twice and they can't give me an answer(no parts man).The old bearing is 2256-31 and I need a number other than 1087 or bca 2065.Thease other bearing would work on my 1555 but not on the 1600.
Lyndell
01-09-2003 15:13:43
 Re: 1600 throw out bearing in reply to Larry, 01-09-2003 09:35:46
The Oliver part number you need was DS-5022. It changed to AGCO number 71121058. The BCA number is 2065-18. Contact me if you need any other info.
Larry
01-10-2003 09:29:06
 Re: Re: 1600 throw out bearing in reply to Lyndell, 01-09-2003 15:13:43
The bca 2065-18 will not work on mine because the grease zerk is on the outside and there is no way to get to it.My 1555 has the opening and can use that bearing.
Larry
01-09-2003 14:30:11
Well the local napa store called their supplyer and they had evan though they could not cross the numbers i had.It just happened the person there had the experience to find it.Napa N1167.
