Thanks for energy cell help folks
gatractorman
01-07-2003 03:00:51
I re-installed the cells yesterday it did help some but didn't fix it, after it warms up a bit it will idle smooth and run good up to mid-range but still got a high end miss, going to check pump timing today (didnt take the book with me) book says 2 degrees ATDC for a 1550/1555, this machine since I been around it always has ran like crap, got to do a rebuild when a liner o-ring failed and dumped coolant in oil pan, upon dis-assembly I attributed the poor running to stuck rings and broken ring lands, it was a son-of-a-gun to start before, starts pretty good now guess I helped it some LOL, Thanks for all the help and advice, I'll keep working on it.
A.P.
01-08-2003 09:45:34
 Re: Thanks for energy cell help folks in reply to gatractorman, 01-07-2003 03:00:51
Try and borrow one of the infared thermometers with the laser pointer (available at many auto parts stores). Start the tractor and let it warm up and check the temperature at the center of the energy cell caps. You may be able to localize the problem to one or two cylinders this way. I was able to determine I have a problem on an 880 with cylinders #1&5 this way. They were running 10-15 deg. cooler than the rest.
Also if the problem shows up under load/at higher rpm check your fuel supply including filters and transfer pump.
Good luck,
A.P.
Larry
01-08-2003 14:25:07
 Re: Re: Thanks for energy cell help folks in reply to A.P., 01-08-2003 09:45:34
Just use your hands you can tell which is cooler.
A.P.
01-08-2003 16:28:30
 Re: Re: Re: Thanks for energy cell help folks in reply to Larry, 01-08-2003 14:25:07
Larry, you are blowing the reasoning I sgave my wife on why I need one. She was all set to buy me one for my birthday.
Seriously, it's more acurate than my fingers, less likely to get burned and can stand more heat than I can. Use a candy thermometer if you would like but I you will probably wind up sleeping on the couch. ;-)
Take care,
A.P.
