OC 3
Chad
01-05-2003 06:13:07
I was wondering what the lift capacity of an OC 3 with loader & 2 factory cast iron counter weights is (weights are rectangular & bolt on back) & what the is the weight of each counter weight is? Also how does the muffler attach to the manifold (mine is broken off)?
Thanks Chad
Gary Hearn
01-06-2003 18:19:03
 Re: OC 3 in reply to Chad, 01-05-2003 06:13:07
The lift capacity will be determined by the condition of your pump, cylinders, etc. I would think that it would pick up 1500#, but with only 3 bottom rollers, it will want to tip forward. I think the weights are the same as the OC-4 which weigh 400# each.
