1600-engine's out!
Don _WI
01-04-2003 14:08:23
Today I finally got ahold of an engine hoist, and managed to get the engine out. Ended up having to split the engine/hydra power to get it out, but came out easy regardless. For the engine, I just welded some peices of chain to 2 1/2 in. nuts and put them on the head bolts for pulling, and worked great. Now I can start dissasembling the goey mess and bring it in to be hot tanked.
Don
P.S. My brother took some pictures, so hopefully soon I'll have them to show.
Jeff
01-05-2003 23:47:40
 Re: 1600-engine's out! in reply to Don _WI, 01-04-2003 14:08:23
Don, my dad just bought a '63 Oliver 1600. Do you know a lot about these tractors. I know the engine cubic inches was increased in '63, but do you know when, beginning of '63? Good luck on the restore, Jeff.
Don-WI
01-06-2003 10:04:16
 Re: Re: 1600-engine's out! in reply to Jeff, 01-05-2003 23:47:40
I'm not sure when they did it, and I haven't measured mine yet, But my Grandpa bought his brand new in 1964, but has the earlier serial number if I remember right and has the 3 1/2 pistons, not 3 5/8. My manual is out by the tractor right now, other wise it has in it what serial number they started the change with. I plan on putting 3 7/8 in it, as the sleeves have probably a good .025 of wear in them. Haven't measured yet, but the pistons are pretty sloppy. Also have a burnt valve in the #3, think it's exhaust.
Don
Wrenchbender
01-04-2003 16:17:58
Don, just a tip on pulling and reinstalling the engine. The two head bolts with threads on them are the balance point for pulling it. They should be together near the center of the head, unless someone put them back in the wrong place. You use the rear bolt when the Hydra-power is on the engine and the front bolt for the engine alone. It sounds as if you already had the head off, but the same positions work without the head. Maybe you already knew this, but thought I'd let you know in case you didn't. Good luck, WB.
Don
01-04-2003 22:45:34
 Re: Re: 1600-engine's out! in reply to Wrenchbender, 01-04-2003 16:17:58
I had the head on, and as far as I know, the engine was never even taken out of the old girl, or worked on. They were farther away from each other, and 1st tried w/ hydra power on, but I couldn't get it to pull ahead far enough, as the bell housing was catching on the engine mounts in the tub. Split the hydra power off, and the engine balanced with the chain grabbing BOTH chains, not just the front or back. Either way, it went very slick, and for reinstallation, I would like to be able to use an over-head hoist, not just a roll-around like I used today. Now comes the fun(and expensive part) of doing a complete rebuild, repaint, and rerubbering the tired old girl.
Don
