Super 77
keith
01-03-2003 20:04:17
I just got a 1956 oliver super 77 and would like to put new oil in the rear end what type of oil do I put and is there a dip stick. Do you put the oil in the hole by the dash. There is a peice of steel in the hole but there is not one in my super 66 that I have for parts. Will the rear end handle 1200 pounds or is that to much.tractor has a loader.
Keddano
01-04-2003 12:19:28
 Re: super 77 in reply to keith, 01-03-2003 20:04:17
Keith,About the 1200#,I think you are asking if it could handle adding 1200# mounted somewhere off the rear axle for counterbalance.I have a 77 that I pull with.It weights 3800#,I've added enough weight to it to pull in 6000# class with about 80% of that on the rear end.So 1200# shouldn't hurt it at all,Just make sure your mounting setup is well supported.
keith
01-04-2003 21:12:35
 Re: Re: super 77 in reply to Keddano, 01-04-2003 12:19:28
I just got 3 more sets of weights and thinking of putting one set on the rims that I have on it now (total of two sets on it and going to put on 2 more hubs put the other 2 sets on the rims off my junked super66
Scott Green
01-04-2003 06:19:48
Keith , skim down a few postings. "Newbie question about transmission oil in super 77. There you will see your answer.
