Tractor games???
greg
12-29-2002 17:36:27
does anyone know of any games using a tractor or two we could use during our antique pull if the sled breaks down, or as half time entertainment? We have thought of rolling barrels with narrow fronts, just looking for any other ideas out there.Thanks, Greg
COWBOY
01-02-2003 11:04:59
 Re: tractor games??? in reply to greg, 12-29-2002 17:36:27
Here is a quick and easy game.
You set 2 long pieces of 2x4's or such about 14 ft apart (Parallel to eachother) with sand or soft dirt between them.
Then you drive the tractor down between them (Like driving across a bridge) and then you measure from the right wheel outer mark to the boards, and from the left wheel outer mark to the left board, then subtract the smaller from the large distance.
Whoever has the smallest number wins. In all actallity, you are seeing who can drive down the center of a imaginary bridge the closest to center.
Be sure to rake the area before the next falla goes through.
missery
12-31-2002 08:29:28
the club i belong to has a summer fest every year.they feature one brand of tractor ,(fordthis year)in a show areana.some games they play is,balance beam.you otta try this.big ramp with a log in the middle.drive upand balance.one shot.tuffer than it looks.i have seen a blind tractor race before. there web site is www.maineantiquetractorclub.com if there is any problem ,post back i will try to fix. dave
Farmall Daddy
12-30-2002 10:18:17
I seen in a magazine, 5 or 6 Farmall tractors were square dancing by spinning in a circle. I never seen anything like that before and never thought of it.
Puller504
12-30-2002 05:08:18
We usually pull 3 or 4 classes at a pull with 2 tractors. IF there is any downtime, I take the kids on a recon trip through the pits to check out the other setups and different ideas that the competition have. Both of my teens are very interested in engineering and applications of ideas, some are excellent, some are dangerous/lame. Lame setups usually = last place! DISCLAIMER:This is only my opinion and you get what you pay for.
George G
12-29-2002 20:40:43
I was at a show this spring. They had an old two wheel trailer made out of a pick-up bed. They had a 6x6 bolted on the front of the trailer and sticking out one side about 6 or 8 ft with a castiron seat out on the end. One person on the seat, one person on the tractor. They had cones set up, each cone had an egg on the top of it. The person on the seat had to pick the eggs off as the driver had to try to maneuver though the cones. They had cones set up so driver had no choice but to back up a couple times though the course. They were timed though the course. Time was subtracted for each egg they collected. And time was added for each cone they knocked over.
kevin m.
12-29-2002 19:42:05
I HAVE SEEN A TRACTOR RACE WHERE THE SLOWEST TRACTOR WINS, IT IS NOT ALWAYS THE 2POPERS THAT CAN THROTLE DOWN.
Signman
12-29-2002 19:11:30
We've enjoyed run and start races. The tractor is stopped and shut off. The tractor needs to be started by hand. The driver runs the 150 feet starts the tractor and drives it across the start line. BE SURE SOMEONE watches that the tractors are out of GEAR for safety.
Another interesting one is to have a wagon backing contest. Some old fifth wheel wagon makes for a real challenge. We Use a couple barrels to act as the barn doors to have the wagon backed into.
JD
12-29-2002 18:11:05
Maybe you guys could do the IH fast hitch square dance.
Canada Grant
12-29-2002 18:09:49
We do an closest to drawpin game . Draw a circle approximatly 10 foot in the middle put a raw egg on a stand [I use a short piece of pipe on a flange] operator backs up to circle puts in clutch and coasts ,No brakes ,up to the egg without tipping or breaking egg. Closest one wins . You can use a sledge hammer same idea but closest to front of tractor without tipping hammer . Shows who is tractor DRIVER or OPERATOR!
Canada Grant
12-29-2002 18:28:43
 Re: Re: tractor games??? in reply to Canada Grant, 12-29-2002 18:09:49
We also do a slow race slowest tractor over 150 - 200 feet and back again last one wins . JD guys don't like this as reverse in a JD is almost as fast as high gear !! In fact one local fair runs the deeres seperate so they can compete!! Probably due to fact organizer is big deere collector. I constantly remind him of this small fact!
