Carburetor parts / rebuild kits
Scott Green
12-28-2002 12:45:31
Oliver 770 started running real rich. Took carb apart. Found crushed float. I'm assumeing ice in float bowl. Where would be a good place to buy a new float / carburetor rebuild kit? I shut gas off at sediment bowl. Tractor began running smooth again.
Scott Green
12-29-2002 11:26:44
 Re: Carburetor parts / rebuild kits in reply to Scott Green, 12-28-2002 12:45:31
Thanks to all who replied. B A Star , I performed surgery this morning. It was a success. The "770" is back to running like new again. You must have done this procedure in the past. I'll see if I can send a picture of the patient.
oliverman
12-29-2002 03:40:04
Korevs Olivers or Rick's Agriparts (330) 264-9720 normally has anything you need.
Ken
12-28-2002 18:02:24
A little work or 33.50 what will it be.
B A Star
12-28-2002 15:46:11
You don't need a new float. Carefully drill a hole with the smallest drill bit that you have and use a little low air pressure to blow it back out, then solder the hole shut. You can tie it to a bolt in a bucket of water and let it sit for a while to make sure it don't leak..... good as new.
larry h
12-28-2002 14:33:49
we sell the floats and the kit for this model for 33.50 for the pair plus shipping
