1650 brakes
dick
12-21-2002 20:17:28
is there a way to get better stopping brakes on a 1650 has new discs and resurfaced lid and cleaned up actuators
Skinner
12-25-2002 05:41:08
 Re: 1650 brakes in reply to dick, 12-21-2002 20:17:28
Did you have to do allot of adjusting on the nut to get them to work? Like they stated, if there shims in there then remove them. My 1650 will lock the tires down with no problem. There was an update also where you had the relocate the hole in the actuator lever by simply drilling a new one. Was suppose to help on the sensativity of the adjustment. The Oliver place here told me when the resurface the covers the make sure to resurface the mating area as well to keep the same clearance.
Gordon
12-23-2002 17:23:00
Get the center actuators. At least try one side I know they are not cheap.
Canada Grant
12-23-2002 19:47:18
 Re: Re: 1650 brakes in reply to Gordon, 12-23-2002 17:23:00
we got improvment by using bigger balls in actuators as grooves were wore badly. Works in older ones too.
Dean Barker
12-24-2002 09:10:58
 Re: Re: Re: 1650 brakes in reply to Canada Grant, 12-23-2002 19:47:18
If your brake covers have shims, take shims out for adjustments instead of turning the nut. I have had good results coating the balls and ball ramps with moly grease instead of leaving them dry. These brakes can work very well if everything is right.
dick
12-29-2002 15:45:54
 Re: Re: Re: Re: 1650 brakes in reply to Dean Barker, 12-24-2002 09:10:58
doesnot use shims on cover what is the pin relocation campain
