What width do i want for 15.5s
new puller
12-17-2002 16:26:53
i have some 15.5X38 tires for my oliver 77 and i would like to know what size width i should get?
of course this would be used for pulling!
thanks in advance
rusty
12-19-2002 07:46:32
 Re: what width do i want for 15.5s in reply to new puller, 12-17-2002 16:26:53
My personal thought that 16" is the best i tryed a set of 18 inchers and they made the tire buckle to much in the center and then you wernt getting all the tread to the ground like you should. Go with the 16" you will like it.
Bob
12-17-2002 21:16:35
I pull a super 88 with firestone field and road mounted on 17 inch rims You need to get a pair of 16 inch rims and than cut and weld an inch into the rim. This will allow your 15.5 low profile tires to stretch out nice and flat to the ground Your outside edge of the lug should be right in line with the edge of your rim. I can take the valve stem right out of my tires and they still wont go flat. Ya only want to run about 4 pounds in them. It works perfect for me. Good Luck
Jeff
12-18-2002 20:32:42
 Re: Re: what width do i want for 15.5s in reply to Bob, 12-17-2002 21:16:35
What part of the country do you pull in? Do they let you use that setup in the Farm Stock class at the local pulls or do you have an open class tractor. Mine is stock but I really like your thinking on the rims but I would probably run into problems using them in farm Stock around here.
Jeff
12-17-2002 18:46:32
I am assuming you are asking what width rims to put the tires on as the tires themselves are 15.5. I have an 88 that i pull and have 15.5's on 14 inch rims. Seems to work real good and the bigger tires actually hook too good sometimes. Of course I am still pulling off of the factory drawbar too. The tires will work on the factory rims but depending onthe track conditions you will have to run the air pressure pretty low to get then to spread out and use all of the tread. You also need to check with the local clubs and stuff to see what their rules say as some most regulate tire size in relation to weight.
My son pulls a Super M with 15.5's on 13 inch rims and it pulls right up there with my 88.
I am sure there are others on here with alot more info on this as I am kinda new at it too.
