Fuel pump
Greg
12-10-2002 13:28:30
Where can I find a replacement mechanical fuel pump for a super 77 diesel?
Terry
12-11-2002 14:02:03
 Re: fuel pump in reply to Greg, 12-10-2002 13:28:30
I recently had the pump on my 88 diesel start leaking fuel. I could not find a replacement pump or diaphragm from my AGCO dealer. What I found was that the 1650 diesel pump has the same diaphragm. I bought a 1650 pump, took the diaphragm out and used it to repair my pump. So, if all you need is a diaphragm, this a one way to fix it.
Bruce Maitland 802-933-6255
12-13-2002 13:46:38
 Re: Re: fuel pump in reply to Terry, 12-11-2002 14:02:03
I purchased a fuel pump for a MF application for about $40 then drilled and mounted arm extension the rest of the pump was the same. Worked OK I have the number if you need it. BM
