Cockshutt 550 wheel locked
Sean
12-04-2002 10:17:00
I recently took possession of a 550. When I hooked the chains up to tow it home the back right tire wouldn't unlock (thankfully the ground was covered in snow - it made the pulling job easier for the JD). I made sure the brake wasn't on and thought I put it into neutral. Did I miss something? or could there be something mechanically wrong?
Also, the proper colour is red?
Dave N
12-04-2002 11:03:17
 Re: Cockshutt 550 wheel locked in reply to Sean, 12-04-2002 10:17:00
Probally you will have to pull that brake apart you will find that it is rusted up
Dave
Sean
12-04-2002 11:28:15
 Re: Re: Cockshutt 550 wheel locked in reply to Dave N, 12-04-2002 11:03:17
Thanks for responding so quickly!
I am a timberframer and project manager by trade - a mechanic I am not. Is it hard to pull apart? or is this something I should pay for?
kenny muncy
12-04-2002 12:12:06
 Re: Re: Re: Cockshutt 550 wheel locked in reply to Sean, 12-04-2002 11:28:15
Remove brake housing on the side that is stuck,should be held on by three nuts,after removal,remove linkage.You should fine two brake
plates with a expander in the middle.You will have to unscrew adjusting bolt from expander to remove the two plates and expander.They will slide off of splined shaft with a little help
and you will be able to free up after removal.
Good Luck.
