Adding PTO
Dennis
11-27-2002 14:13:34
What is involved in adding pto unit to a tractor that did not have one? If you have an extra parts tractor wtih the pto will that work? Is it driven off of the powershaft?
Dave, Sherburne, NY
11-28-2002 19:34:47
 Re: Adding PTO in reply to Dennis, 11-27-2002 14:13:34
Had a problem with the pto om my 1950, previous owner had apparently removed the engine before he took out the pto shaft, and bent the shaft alittle. the splined piece on the flywheel eventually sheared the bolts, and presto, no pto. Time consuming fix, six bolts I think it was , straighten the shaft, and put it back together.
Larry from Maryland
11-28-2002 15:08:05
The one problem is if the spline is not mounted in the flywheel.The detroit takes a differant piece than the 1850.
Pete
11-27-2002 17:36:35
Dennis
Need to know the model that you are talking about!
Pete
Dennis
11-27-2002 18:12:00
 Re: Re: Adding PTO in reply to Pete, 11-27-2002 17:36:35
Tractor is a 1950 Wheatland. It has no pto. Have an 1850 parts tractor available with one. Will it work?
WFE
11-28-2002 08:10:58
 Re: Re: Re: Adding PTO in reply to Dennis, 11-27-2002 18:12:00
Should work. Good luck. Same pto drive used on 1850 & 1950 GM or T.
