I'm new to Olivers
Dev.
11-23-2002 07:52:38
What is the difference between Hydra-Power, and the Over-Unders shift? Thanks
Super 55
11-23-2002 09:25:59
 Re: I'm new to Olivers in reply to Dev., 11-23-2002 07:52:38
I'm fairly new too, so I looked them up in my Oliver books. The over-under allows you to shift each of the 6 gears either into underdrive or overdrive giving you 18 gears. As far as I can tell from the section on the Hydra Drive it only lets you downshift each gear giving you 12 gears. I'm sure someone will give a lot more info.
Scott Green
11-23-2002 15:41:13
 Re: Re: I'm new to Olivers in reply to Super 55, 11-23-2002 09:25:59
Super 55 , You did just fine.
