Oliver 1850?
David
11-18-2002 13:27:22
I am going to look at an Oliver 1850 for my dad. What are some quick check items I should look for.
Trans?
PTO?
Start up problem?
This is a 1968 modle with about 6000 hrs. I don't know if the engine has been overhauled, tires are about 50% and it has a Hinker cab.
What would be a fair price if it checks out ok?
Thanks for your help,
David
Larry from Maryland
11-18-2002 14:38:13
 Re: Oliver 1850? in reply to David, 11-18-2002 13:27:22
Well with the engine running fairly fast you should be able to hear the preasure relief pop between your legs when you yank back on the hydrolic levers.If not suspect a weak pump.Allso the steering should work some when the engine is running slow.Look for looseness in the steering and air bubbles in the raditor.
