1650 Steering Problems
Tim
11-17-2002 17:39:30
I'm going to look at 1650 that's for sale. It doesn't steer. Any quick diagnosis? $?
thanks
johnnye
11-24-2002 12:27:42
 Re: 1650 Steering Problems in reply to Tim, 11-17-2002 17:39:30
We bought a 1655 that didn't steer. I jumped the gun and bought a used Charlynn steering motor. Upon farther inspecton, we found the yoke off the steering shaft on front was stripped. MUCH cheaper solution! I still have the steering motor if you need one
Rick
11-20-2002 04:35:36
Tim, You said you were looking at 1650 to buy. I have one for sale if interested,also know wher you good get some steering parts if you do go that route
Rick
11-22-2002 20:42:14
 Re: Re: 1650 Steering Problems in reply to Rick, 11-20-2002 04:35:36
What is the tip on locating steering parts for an Oliver? Need a working telescoping column or parts to fix one?
jimbe
11-20-2002 17:10:13
the first thing that i would do is check the priority valve. it is located on the left side of the hydraulic unit. there is a spool in the valve that will sometimes stick. symptoms are steering but no hydraulics or hyd but no steering. cures a lot of them and costs nothing!
JIm H
07-19-2003 06:54:58
 Re: Re: Re: 1650 Steering Problems in reply to jimbe, 11-20-2002 17:10:13
I'm having similar problems with my 1800: soon as I start 'er up, she starts turning left. Can't stop it. Repair guy says I have to replace entire unit at +-$1000. Would 1650 problem and solution be similar?
Tim
11-20-2002 18:07:05
Everybody,
The price was right, so we'll be bringing the old girl home. I've wanted an Oliver for thirty years and now the fun begins.
Where's a good source for a Char-lynn valve unit? The QF&F and Central Tractor stores in my area have all closed.
thanks
Tim
Sam M
11-18-2002 07:27:55
You are asking a real tough question . Could be major problem like bad hydraulic pump , bad steering motor underneath the dash , or bad steering cylinder at the front of the tractor , bad steering by pass or pressure relief valves , each of which would have their own problems and expenses . Replacing the hydraulic pump would probably be the most expensive . Do the other hydraulic driven systems (the 3 point hitch and remote valves ) work ? If they do not work that would make me lean toward a bad hydraulic pump or problems with one of the main hydraulic valves . I have also heard about the splines being worn on the pto drive shaft (which also turns the hydraulic pump ) and this causing the hydraulic pump not to work.
tim
11-18-2002 16:02:41
 Re: Re: 1650 Steering Problems in reply to Sam M, 11-18-2002 07:27:55
Sam,
The PTO and 3 pt were working. The owner believes it's the steering motor below the dash.
Is that a common problem?
Larry from Maryland
11-20-2002 14:58:31
 Re: Re: Re: 1650 Steering Problems in reply to tim, 11-18-2002 16:02:41
Yes it is I have replaced 3 with charlin steering valves.One time I tryed a rebuilt one it failed after 200 hours.One time I replaced the seals myself and that one exploded hot hydrolic oil all over me 2 months later.Thats why I like to replace with charlin.The charlins allso steer easyer and you don't have to constantly turn the wheel to keep going straight.
Sam M
11-20-2002 07:24:42
The pto on the 1650 is manually started and the pto runs off a splined drive shaft that goes into the fly wheel . A set of splines part of the way up the shaft turn gears which drive the hydraulic pump . The splines which turn the hydraulic pump can be worn and the pto still work so I am not sure how much the pto working tells you about the hydraulic pump . The fact the 3 point hitch wokrs would seem to indicate the hydraulic pump is working and pumping fluid . Do the remotes work ? When you pull back on the remotes does the pressure relief valve make noise which would indicate the hydraulic pump is working ?
I have not run into a steering motor that completely failed but have rebuilt two that were weak and leaking oil . AGCO sells a seal/o ring rebuild kit if that is the problem . You may be able to find a used parts dealer that would sell you a rebuilt one or contact someone on this web site . The Steering motor is fairly easy to get to and remove once you remove the sheet metal and the diesel/gas tank . I have not had any luck trying to get to the steering motor going through the dash .
Bob
11-18-2002 20:32:10
I have one of those pumps in the dash off a 1650 that i wrecked. If your interested e-mail me Thanks
