RC 60 oil pan
Barry-KC
11-15-2002 19:37:58
I want to drop the oil pan on my RC 60 and clean out the sludge. At the back end of the pan there is a sheet metal panel that fits over the lower front portion of the bell housing. It looks like this panel has to be removed to expose the last few bolts on the oil pan and I can only see two fasteners at the bottom of the panel. Is the panel removal that straight forward or am I in for a XXX good time!?
Are the oil pan bolts on the left side (half hidden by the steering shaft) accessible without dropping the steering shaft?
Appreciate any guidance,
Barry
Geoffrey
11-16-2002 05:17:14
 Re: RC 60 oil pan in reply to Barry-KC, 11-15-2002 19:37:58
That little piece of sheet metal is the dust shield. Just remove the two bolts retaining it and slide it down and the oil pan bolts should be exposed. I think I had to bend mine just a little to get it out. As for the steering shaft, it has to be removed to allow the pan to come off. Take out the two bolts at the very front coupling and slide it back on the shaft until it clears.
Barry-KC
11-16-2002 06:08:02
 Re: Re: RC 60 oil pan in reply to Geoffrey, 11-16-2002 05:17:14
Thanks Geoff
That's exactly the info I needed. Now it's just a case of paper towels, bandaids, 3 sets of clothes and a very LOUD radio and I should have it whipped!!!
Barry
