Oliver 1265 purchase
MATT
11-12-2002 16:10:31
I'm looking at buying an Oliver 1265 and would like to know what everyones oppinion of this tractor is. It has a full hydraulic bucket and souunds good to me. I would like to know about common problms. It is a Fiat deisel model.
redekelmo
11-13-2002 00:41:29
 Re: oliver 1265 purchase in reply to MATT, 11-12-2002 16:10:31
had considerable experience with a 1255 with loader.think it's just an older version of the 1265. it's been a very reliable tractor the fiat motor has never been touched.as a chore tractor the thing was everything you would want very fuel efficent enough power to pull a 6ft bush hog or run an auger.the one I'm familar with has had only the best care also you know check the oil once a month change it every other year or so ect. I think other than irregular service the tractor has had 1 clutch 1 set of brakes a startor rebuild and some small stuff. that said parts are hard to find the last I heard
dwm
11-12-2002 19:44:08
Long ago had a new Oliver 1250, also a Fiat. Would not recommend it. We had engine problems within the first year and traded off for larger, U.S. Oliver.
Dsl
11-14-2002 06:42:58
 Re: Re: oliver 1265 purchase in reply to dwm, 11-12-2002 19:44:08
Don't compare the 1250 to the 1265-no comparisan at all! Like the 1265, the 1250 was very nimble, and nice to drive, but from the transmission forward, the 1250-A was a near total re-design of the 1250, and a vast improvement in reliability in the engine and electrical departments. The 1255 was the same as the 1250-A, but just given a new model number to match the rest of the new 55 Series. The 1265 was given a bigger bore for more power.
The 1265 is one sturdy, peppy, long-life lil tractor, a delight to drive, and easy to service. Highly recommended. Just make sure the final drives didn't have water in them or the bearings could be bad.
Mike (WA)
11-12-2002 18:10:40
The knock on the Fiat Olivers in the past has been parts availability- but now Dsl is "in the business" and should be able to help. His site is www.sphosting.com/dsl/index.html From posts I have seen, they are a fairly reliable tractor, and if the parts problem is solved, should be a good purchase.
ol George
11-12-2002 21:13:57
 Re: Re: oliver 1265 purchase in reply to Mike (WA), 11-12-2002 18:10:40
There is a tremendous difference in the 50 series to the 65 series. We have a 1365 4wd with a 1510 loader has been used long and hard and still runs well. Don't have much experience with the 1265 but if it works as well as our 13 then I wouldn't be scared one bit. The 50 series is a different story altogether.
1265
11-14-2002 02:31:11
 Re: Re: Re: oliver 1265 purchase in reply to ol George, 11-12-2002 21:13:57
I agree with ol george. The 50 series were not as good as the 65 series. While many will disagree, from a chore standpoint, the 65's are amongst some of the most reliable Olivers ever built. They have been known to produce over 9000 hours with little maintenance. I like the 1265 and 1365 and believe you will be getting a good unit. However, if one is wore out it may be worth avoiding. I heard that it's a good idea to run one awhile before purchasing to see how engine acts once warmed up very good. Look for leks around head.
