Do you coat your head gaskets?
Kelly
11-11-2002 22:29:31
Going to put a new fiber head gasket on my Waukesha, do you put any grease, oil or stuff on it?
Steven@nd
11-12-2002 16:25:49
 Re: Do you coat your head gaskets? in reply to Kelly, 11-11-2002 22:29:31
Yep, on the gaskets that say "use sealer" on them. The other ones I don't worry about. Just be sure to retorque the head bolts.
WFE
11-12-2002 06:55:20
Only thing I have used is a product from Permatex called Hi-Tac. It is a sort of high strength gasket adhesive that can help engines that are tuned up to higher compression ratios with an overhaul or engines that notoriously have problems retaining head gaskets. I apply a light application to both sides (very light). So far it has worked very well on the engines I have upped compression on.
