Super 55 Hydraulics
Scott
11-10-2002 23:26:36
I have recently purchased a 1955 Super 55. The hydraulic system was full of water and old oil. I was told to use 9 quarts of Type 55 hydraulic fluid, but after pumping the old oil and water out, changing the filter (it's on the side), and putting in 2 gallons and most of a pint it is overflowing. My I&T manual references "Early Unmodified Tractors" that hold 6 quarts. Is this possibly what I have? Am I using the proper oil? Thanks!
Super 55
11-11-2002 09:16:11
 Re: Super 55 Hydraulics in reply to Scott, 11-10-2002 23:26:36
There was a change to the reservoir starting with tractor # 23 131-500. The reason being that the oil in the older models would shoot across the top of the oil and mix air with the oil causing a partial vacuum, resulting in considerable noise, and pump failure. Go to the link below to see how to convert your tractor if it is prior to the factory change. It will show you how to convert yours. Use 10W30 in the reservoir according to the manual, unless someone has an updated oil suggestion.
Scott
11-11-2002 21:50:36
 Re: Re: Super 55 Hydraulics in reply to Super 55, 11-11-2002 09:16:11
Thanks for the info and the link. I really appreciate the help, this is my first antique tractor. If I understand whats on the link, it's basically changing the location of the vent and adding the standpipe. My I&T manual lists these mods for early tractors with external control valve and remote cylinder. Could you possibly explain to me the difference from the "manual selector" to the "double feed-back" system. Also, I don't understand drilling more than one hole for the vent relocation. The dealer that was recommended to me for parts made the suggestion on the "Type 55" oil. I want to be sure, your saying 10w-30 "motor" oil, right?
jake
11-11-2002 22:18:10
 Re: Re: Re: Super 55 Hydraulics in reply to Scott, 11-11-2002 21:50:36
If the filter is on the left side of the housing it is the early type which the adapter can be used to raise from 6 qts. If the filter is on the front of the housing that is the later 9 qt. The manual selector has 1 external adjustment and 2 internal. The double feed back is distinguished by having a single control lever instead of control lever and a selector, the single adjustment can be made without disturbing the housing. When you drained the system did you remove the 3/8 pipe plug on the right front and let the pump evacuate the system?
Scott
11-12-2002 07:26:41
 Re: Re: Re: Re: Super 55 Hydraulics in reply to jake, 11-11-2002 22:18:10
Yes, I took the plug out and installed a nipple and hose. It pumped out about 3 quarts of water, 3 quarts of a milky mix, and about 1 quart of really thick oil. Do I need to be concerned about converting mine from the "manual selector" to the "double feed-back" system or do I just need to convert to the stand pipe and move the vent? About all I will be doing with the lift is using a 3-point bush hog, a scraper blade, and maybe some light cultivation. What about the oil? Type 55 or 10W-30 "motor" oil?
Mark
11-12-2002 10:21:59
 Re: Re: Re: Re: Re: Super 55 Hydraulics in reply to Scott, 11-12-2002 07:26:41
I didn't see anyone else really address your oil question, so I'll give you my thoughts. I just rebuilt a super 55 hydraulic system, after serial 46,000, so it's double feedback, but the oil I used was the common hydraulic fluid available at TSC or other farm stores. It works fine. No problems. Fully compatible with the Buna-N orings you have in your hydraulic system.
jake
11-12-2002 08:44:48
The only reason for the upgrade is to have more oil available for a loader or other external cylinders, the 6 qt is all you need for the 3pt. I would be concerned about is getting the tank clean and frequent filter changes till the oil is clear. A good grade 10W-30 for all seasons [or 10 cold and 30 for hot]. With the mess pumped out possible damage to the piston O ring or other internal parts, change the filter filler up and hope. Good luck
jake
11-12-2002 09:03:12
 Re: Re: Re: Re: Re: Re: Super 55 Hydraulics in reply to jake, 11-12-2002 08:44:48
I have never heard of the condition brought up by Super 55 before however he has more information available on hand[sorry Paul]. I have 2 super 55's one early and the other the later. This winter I might make up a riser tube for my older 55.
Super 55
11-12-2002 22:04:53
 Re: Re: Re: Re: Re: Re: Re: Super 55 Hydraulics in reply to jake, 11-12-2002 09:03:12
I just bought the manual is all. The $$$$$$ one. It does have a lot of info. As to the question about why all the holes on the breather. The center hole is for tapping for the breather cap screw . The two smaller holes are for the breathing. I am going to do the up grade on my tractor soon. I have it apart anyhow. It's pretty basic, and I have some external hydraulics to attach.
jd
11-11-2002 05:33:12
Mine of about the same vintage only took 6 quarts. I used 10w30 oil. I don't know what type 55 is. Hope this helps. JD..... ..... ..
