Choke knob S77
paul
11-07-2002 20:20:57
The knob on the choke has worn loose & pulled off. Looks like the choke rod is threaded. Does Agco sell just the plastic knob, does anyone else, or what?
This is on an Oliver Super 77.
--->Paul
Gary
11-08-2002 17:34:27
 Re: choke knob S77 in reply to paul, 11-07-2002 20:20:57
You are better off with the Agco one because it has a stainless steel wire in it which does not rust and stick. It will cost more but at least it will still work 5 years from now
WFE
11-07-2002 22:36:02
Sounds like the cable end which is threaded to accept the knob has worn threads also. You will probably be time and frustration ahead to just buy a new choke cable from your nearest hardware store that is the appropriate length. AGCO dealers can get you one as well if they are nice and close.
