Painting a 1650
Kevin McCann
11-05-2002 16:42:13
I am in the process of doing a complete paint job on a 1650. I need some help with the color of the rear wheels. What color are the clamps that hold the rear rims to the cast iron center suppose to be of the three Oliver colors (green, white, red)? What color are the bolts that hold the cast iron center on suppose to be? Finally, what color are the cast iron rear wheel weights suppose to be that bolt to the cast iron rear center?
Thank you for your help.
dwm
11-06-2002 08:48:41
 Re: Painting a 1650 in reply to Kevin McCann, 11-05-2002 16:42:13
That's probably the way to go, and there is no red. If you want to get technical, at least from 1968 or so forward when the tractors were new, the bolts were not painted. That goes for both the bolts holding the clover white cast center to the meadow green hub u-bolted to the axle and the rim clamp bolts. The rim clamps were kind of a gold anodized natural color. The rims were clover white. On the tractors with spin-out rims, the cast center was still clover white, but those rims were silver in color. All the weights from the late 60s on were also clover white. Good luck on the paint job!
Shep
11-05-2002 16:55:53
I have always painted the wheels, rims, weights and holders on the rear wheels clover white, the center hub and wheel bolts are meadow green. I dont think there is supposed to be any red on the 1650.
Jim T
11-05-2002 20:24:48
 Re: Re: Painting a 1650 in reply to Shep, 11-05-2002 16:55:53
I think Shep has it right!
