Oliver has a miss
Steven
11-01-2002 14:26:02
Scott green
11-01-2002 14:51:01
 Re: Oliver has a miss in reply to Steven, 11-01-2002 14:26:02
I would say that the carb float is not ajusted properly. Or , maybe you have a hole in the float. Gas leaks in the hole , and weighs the float down enough so that gas always runs. No matter how much you ajust the needles , it still runs rich. Maybe something is stuck in the float needle.
steven
11-01-2002 15:15:30
 Re: Re: Oliver has a miss in reply to Scott green, 11-01-2002 14:51:01
It seems like its just a couple of plugs that are fowling dark powder, the other four are ok. Do you think maybe intake leak or valves?? Someone else had that idea. If it was the carb wouldn't all the plugs be rich??? Appreciate the help, you guys know gobs more than I could ever hope too!!
Scott Green
11-01-2002 16:01:03
 Re: Re: Re: Oliver has a miss in reply to steven, 11-01-2002 15:15:30
Steve , try spraying carb cleaner around intakes on manifold. See if the engine wants to die out. if so , then I would say it was intake manifold leak. Otherwise , I would check out the carb /float/ect..
IanC
11-01-2002 18:16:17
 Re: Re: Re: Re: Oliver has a miss in reply to Scott Green, 11-01-2002 16:01:03
The Idle mixture adjustment on a M/S carb is opposite of a "normal" jet, in is rich and out is lean. You may be turning it the wrong way.
