Antique Olivers for pulling
Glenn S. Decker
10-31-2002 01:11:52
I'd like to try antique tractor pulling, but have not had much luck finding information on the subject. From what I have seen, Olivers have a really good combination of weight and horsepower for this purpose. I've had one puller I met suggest that a 66, 77 or 88 would be a good tractor with which to start, but I'm still looking for more information about how to set a tractor up for pulling. Any thoughts? Thanks, Glenn
KEDDANO
11-06-2002 20:56:37
 Re: Antique Olivers for pulling in reply to Glenn S. Deckert, 10-31-2002 01:11:52
I PULL A "77",if I did it all again,I'd start with a "88",They carry more HP in almost the same package as the "77". except the upgrades are easiser to come by(intake,carb,etc),just my thughts,Dan
joe cool oliver 66
10-31-2002 10:22:36
My 66 does an excellant job in the 3,000 and 3,200
class. could use more ponies for 3,500. drawbar at 20 inches helps. check compression, more compression, more power, use a better grade of gas, This will help you get started.
MISSERY
11-05-2002 18:40:22
 Re: Re: Antique Olivers for pulling in reply to joe cool oliver 66, 10-31-2002 10:22:36
HOW ARE YOU GETTIN THAT 66 IN THE 3000 LB CLASS?
greg
11-06-2002 08:21:07
 Re: Re: Re: Antique Olivers for pulling in reply to MISSERY, 11-05-2002 18:40:22
Pressed steel rims, 12.4x38 rubber, no pto, plus my chubby butt, 2,990lbs.
