Oliver 1950-T
Brad
10-13-2002 19:23:28
I am wanting to know where I can get a bigger camshaft for my 310 diesel. I think I have to get it made from my stock one, but i'm not sure. I think WFE said he has one in his pulling tractor. Anyway please post some info WFE and everyone else.
WFE
10-14-2002 21:05:25
 Re: Oliver 1950-T in reply to Brad, 10-13-2002 19:23:28
Brad,
I've not taken that step yet in the 310. Perhaps someday. Have done it in Fleetlines and Supers (non-turbo) with good results. We are limited to stock turbos in our classes, but the 310 would benefit, I believe, from more air from a bigger turbo, coupled of course with more fuel from modified pump and injector nozzles. It's going to take that to compete against the cubic inch disadvantage the 310 has versus the highly competitive IH 1066s in my classes. My basically stock 310 holds strong at 150 hp. The above mods can pretty easily take the 310 well above 200 hp, but one would certainly be looking at getting hardened or custom rods, among other things. In the Fleetlines, we have gone through Barron's Motor Supply to have cams built up and reground, and I believe they will stroke crankshafts as well. Then they send them off to a central machine shop. Have also worked through a local racing engine builder to have mods done. I would start with one of these guys in your area as it is their forte. Good luck!
M kuhns
10-14-2002 17:23:59
Crane Cams, and Lunati Cams can make you one up depending on what for Rpm's you are willing to turn.
