Oliver 550 stay rods
Dave
10-11-2002 20:12:19
Any ideas on how to tighten the ball and socket joints on the stay rods to the front axle of a 550? Would a piece of leather or neoprene (or aluminum/tin sheet metal) crammed around the ball and fitted/forced into the socket do any good? Or is there a way to build up the ball or socket parts?
Also, my right tire has always worn more on the outside of the tread, no matter how I adjust the toe-in. The bearings seem okay and the wheel rotates smoothly when jacked up. The whole wheel and tire assembly look to be slanted in at the bottom. Could a previous owner have replaced the front axle assembly with a different/incorrect one? In the parts book I see there were 3 different part numbers on each side for this item. Where is the part number usually located on the axle extension? I don't have my serial number handy right now, but it was built in mid-1962, has the metal front grill, and an Oliver Corporation, Charles City, Iowa tag.
Mark
10-13-2002 17:16:06
 Re: Oliver 550 stay rods in reply to Dave, 10-11-2002 20:12:19
I built mine up with weld on the ball.
The sockets didn't need anything, just the balls.
It was cheap and you can't tell I even did it.
jake
10-12-2002 06:10:28
Don't bother trying to build up the ball or cap, new caps are available from any dealer[cheaper by buying fron Mailbach or Korves. A set cost me $22.00 and makes the job right. The loose rods could have caused the tire wear, toe in should be 1/8. The ends on the front axel if correct will have grease zerks facing forwards.
Dave
10-12-2002 19:01:26
 Re: Re: Oliver 550 stay rods in reply to jake, 10-12-2002 06:10:28
Any dealer? Do you mean any Agco dealer or any dealer with access to aftermarket parts through TISCO or A & I, etc?
jake
10-13-2002 10:06:25
 Re: Re: Re: Oliver 550 stay rods in reply to Dave, 10-12-2002 19:01:26
Any Agco dealer. White tractor handles Oliver parts however it,s going to cost more from them.
