Converting 77 to alternator
TeeJay
10-08-2002 17:58:31
Can you convert a 77 to an alternator in place of the generator, if so, what model alt do you need and is there an installation kit available
Thanks
TeeJay
Keddano
10-09-2002 18:42:08
 Re: converting 77 to alternator in reply to TeeJay, 10-08-2002 17:58:31
I don't know of a kit,But the easy way is to get a one wire alternator(GM style)My rebuilder will convert one for $20.00(check with a small rebuilder),making the brackets are easy.Check out the article on this website "Upgrading an Oliver Super 55 Electrical System" it should be close to the 77 hopes this helps,Dan
Link
Gary
10-09-2002 05:31:23
If you are after 12V you can also send your old generator to a shop and they can convert it to 12V for the pice of a rebuilt one.
IanC
10-08-2002 18:21:48
If you want the alternator to get 12V to spin the starter faster find a 12V generator from a 770 or 880. It should bolt right up and still look pretty stock.
