Oliver 1600 diesel
Keith
10-05-2002 18:40:33
I have a 1600 diesel that goes into gear but when the clutch is let out it doesn't move. There is oil leaking from the trasmission area any idea what is wrong?
Richard
10-10-2002 03:47:50
 Re: Oliver 1600 diesel in reply to Keith, 10-05-2002 18:40:33
Or, if you happen to be like my wife, the emergency brakes are set .
When you say it won't move, does the engine die when you let out the clutch or lug down? A buddy has a 1950 that rolls fine until you put in gear (any gear) then it locks down the wheels and the engine. His Hydrapower (o/u) spins fine and so does the coupling so it appears to be in the tranny. We're going to tear it down when it cools off some outside. Hopefully it's some simple but I bet it's a bearing. He stated he was on the hwy coming back from the hay feild when it started squeling so he pulled over to check it out and it hasn't moved since.
Larry from Maryland
10-06-2002 09:38:32
You are moveing the shifter rail but not the gears,that means one or more of the shift forks are broken.Most likly its the high/low fork.
