Oliver 1550/1650??
Craig
09-27-2002 18:15:25
I was looking at a 1550 today and could not see much difference between it and my 1650... What are the major difference between the two? are most parts interchangable?
Craig
Larry from Maryland
09-28-2002 09:09:01
 Re: Oliver 1550/1650?? in reply to Craig, 09-27-2002 18:15:25
The 1550 has the older smaller engine that has the oil squirted down into the rods.the 1650 has a fully preasureised crankshaft.The 1550 has the old style slideing gear transmission and the 1650 has a constant mesch transmission.The 1650's are much easyer shifting.
Craig
09-28-2002 09:32:42
 Re: Re: Oliver 1550/1650?? in reply to Larry from Maryland, 09-28-2002 09:09:01
Would the bellhousings be the same?
Thanks
Craig
Larry from Maryland
09-28-2002 14:54:32
 Re: Re: Re: Oliver 1550/1650?? in reply to Craig, 09-28-2002 09:32:42
I allways thought they where differant,but never held them up to each other to find out.The 1650 has a larger 13" clutch too,but it bolts to the same holes as the 12".The pto's are differant too with the 1650 an oil clutch and the 1550 dry.The dry one is easyer to work on.
Craig
09-28-2002 15:17:48
 Re: Re: Re: Re: Oliver 1550/1650?? in reply to Larry from Maryland, 09-28-2002 14:54:32
Thanks!! Larry, I found a 1550 Tricycle and no rear wheels pretty bad shape at a scrap yard, my 1650 has a broken bellhousing and I also need the P/S parts for a conversion. Scrap man wants $0.15/Lb So I am debating if I should by the whole machine ( I figure $700-$800 ) or just go in and get what I need
Craig
kevin m.
09-28-2002 18:25:13
 Re: Re: Re: Re: Re: Oliver 1550/1650?? in reply to Craig, 09-28-2002 15:17:48
was it a gas? if it has agood head that would raise the eye brows of those of us who own 77's. let me know.
Craig
09-28-2002 20:20:11
 Re: Re: Re: Re: Re: Re: Oliver 1550/1650?? in reply to kevin m., 09-28-2002 18:25:13
I know where a LP 1650 is What about that head???
Craig
Craig
09-28-2002 20:18:07
Not it was a diesel...sorry
Craig
