Oliver 88 questions
Brian
09-25-2002 16:36:22
Hi all,
I have a '51 Oliver 88 Row Crop (narrow front). I am looking for a good BASIC manual to give me information on fluids, fluid types, maintainance needed, tune-up specs, etc.
I have a Oliver and Cockshutt I.T. shop Service Manual from Intertec, but that is more for rebuilding and does not have that kind of information.
I am very new to tractors and would appreciate any leads on good manuals or web sites to get me started.
I am also interested in putting a wide front on this tractor. Any suggestions?
The last thing I want to do (for now) is put some kind of loader on this tractor. Something for snow/ manure/ etc. There is a Hydra-Electric pump on the tractor all ready. Any leads for this would be appreciated as well.
Thanks,
Brian
Kilian
09-26-2002 09:33:43
 Re: Oliver 88 questions in reply to Brian, 09-25-2002 16:36:22
What you need to get is the Operator's Manual for the 88. The best place to go through is the Floyd County Museum in Charles City, Iowa. I don't know the number off hand, but you can do a search on this site and find it. They charge around $20 for the manual, with a little more for postage. This manual will tell you all about fluid capacities, recommended weights for different temps, etc.
I'd also recommend getting a parts manual if you are going to do any work yourself, as it gives a lot of good exploded views of parts and how it all fits together. The Floyd Museum would have that as well, and it's about $35-40.
As for a wide front, I did the same for my 88 Row Crop which had come with a narrow front. Check this site (do a search for "wide front" etc.) and find out what will fit the 88, then run an ad in your local shopper or watch the ads. A wide front can be pretty heavy, depending upon the type, so it's best if you can buy it locally (expect to pay between $300-500, but may vary for your area depending upon how popular the Oliver dealer was). Once you have it, it's a pretty easy swap.
Hope this helps.
Jerry B
09-26-2002 07:53:38
I&T manual number O-201 has all this info and more for 66-880 Supers, regulars, gas and disels.
Espect to pay about $25 or so for it.
