Head bolt torque?
G. L. Perry
09-21-2002 08:51:01
Have an Oliver 66 with 4 cyl. gas engine. Need the head bolt torque. I assume the pattern would be alternating from center out? I ordered a gasket kit for it. They couldn't tell me what gaskets were in it. Anyone know? Got from Napa. I'm hoping the one for the upper water outlet is in there. No oil seals on the valves?
WFE
09-21-2002 19:48:13
 Re: Head bolt torque? in reply to G. L. Perry , 09-21-2002 08:51:01
Usually the head gasket is included. What you won't get are the front and rear main seals. There should be valve seals in the kit for this tractor.
Super 55
09-21-2002 09:06:08
Head torque is 92-100 foot pounds.I'll try to show the pattern below. This would be with the water inlet at the left.
9.....6....1..... ..4..... ...10 (oil screw)
8.....5.....2....3..... 7....11
number 2 bolt is the lifting adapter cap screw.
