Correct radiator cap for OC-3
Lionel Charron
09-20-2002 07:14:44
I cannot ID my OC-3 exactly as there is no tag on it but it seems to be an early one. I'm generally using 1951. My question is concerning getting the correct radiator cap for the system. My OC-3 parts book (Dec./55) shows two different caps; one being the same as the HG and another for 12WH660 up. There is also a listing for a pressurized cooling system kit.
My radiator filler neck does not have any seat that a conventional pressure cap could seal against so I don't think I have the pressurized sytem.
Which cap should I get and where? I will try Landis Zimmerman if there is not a proper aftermarket one available, but I should give him some proper information.
Any help will be appreciated.
Lionel
