White backhoe
gatractorman
09-19-2002 02:57:31
I'm looking for an engine kit for a White backhoe model 2-63-15 (6-cyl. Waukeshau diesel), I have access to farm tractor engine kits but dont know which tractor would have this same engine, can anyone help?
IanC
09-19-2002 18:54:02
 Re: White backhoe in reply to gatractorman, 09-19-2002 02:57:31
2-63-15 engine was a 1550/1555. When re-installing your engine be VERY carefull with torque convertor hook up, as I remember total run out axial and radial was something like .006"
gatractorman
09-20-2002 03:16:23
 Re: Re: White backhoe in reply to IanC, 09-19-2002 18:54:02
Thanks IanC been havin' a hard time finding anything about this hoe, he's already been havin flex plate problems with this tractor the guy he got it from had put a bunch of them in already, do you know the procedure for lining this thing up?, I know I'll hafta shim under the mounts and such but how do I know when I get the driveline within .006?
IanC
09-23-2002 17:58:06
 Re: Re: Re: White backhoe in reply to gatractorman, 09-20-2002 03:16:23
Talked to the mechanic today. He's pretty sure it's in both of those plus the I&T manual. He doesn't remember the procedure for aligning the reverse-o-torque to the torque converter and flex plate other than it was a pain. If you don't have access to those manuals call Landis Zimmerman of the HPOCA, and he might be able to hook you up with somebody in your area who is familiar with the industrials. Good luck.
IanC
09-22-2002 18:48:59
When the dealership I worked for sold out I only bought their Fleetline service manual. I don't remember if the procedure was in the 1550 service manual (2-62-xx), or the 1650 manual (1650 was the 2-78-xx, and 4-78-xx). I'll try and call our old head mechanic and see if he remembers where to find it.
