Super 55
PTO/Drive Oil seal removal/installation
Dan Cox
09-18-2002 21:26:15
I have my Super 55 Split to replace the PTO clutch plates and oil seals/o-rings. I found that the guy I bought it off of had put the oil seal for the PTO pinion shaft in backwards and had crushed both o-rings for the bearing retainer behind the pinion shaft and the one behind the PTO spider!
What I need to know is how to safely remove the oil seals from the bearing retainers and then the best way to install the new ones. I will also be replacing the oil seal at the rear of the PTO shaft and the associated felt washer.
Also, how do I know the correct direction to put the seals in? should the part numbers always face away from the oil??
BTW: For those of you that have been following my work on the tractor to date.. What caused my PTO plates and the three clutch arms/links to break was not my finish mower shaft locking up as I suspected.. it didn't lock up.. The Allen set screw on the clutch came loose due to the oil leak and the whole clutch assembly moved forward and jammed...
Dan
jake
09-19-2002 09:03:48
 Re: Super 55 - PTO/Drive Oil seal removal/installation in reply to Dan Cox, 09-18-2002 21:26:15
The seals are installed with the open side facing the fluid [trans etc]. Removal of the old seals by driving them out while supporting the housing, reinstalling is best done with a press with proper driver. The "O" ring on the hub shaft is lubed and slid over the spline and should be coated with a good grease when prior to sliding the hub back in place. Was the set screw centered over the recess that it locks into and worker its way loose? Replacement 2 pc lock screws can be purchased or easily made. 1 5/8 and 1 3/8 long screws
Dan Cox
09-19-2002 10:54:49
 Re: Re: Super 55 - PTO/Drive Oil seal removal/installation in reply to jake, 09-19-2002 09:03:48
Jake,
I have a 1955 model.. It did not have the dog point and lock screw combo to secure the clutch...just an allen screw. It worked its way loose from the recess and the whole clutch assembly moved and jammed. I am replaceing that screw with the new version that includes the dog point screw and lock screw..
As for the seals.. thanks for the info.. I need to figure out how I am going to install them without a press..
Oh, Do you have any pics of the tool you made for removing/installing the spanner nut for the PTO spider? I'm going to need it to get it back together?
Thanks!
Dan
jake
09-19-2002 22:04:41
 Re: Re: Re: Super 55 - PTO/Drive Oil seal removal/installation in reply to Dan Cox, 09-19-2002 10:54:49
Dan the seals can be driven into the seats by laying the housing on a solid base and a flat plate using a hammer or vice to press it, be careful not to tilt the seal in the process. Sounds like the other guy put a common set screw in stead of the original which also had a dog point. I still don't have a scanner however the tool is a 2 ft piece of 2" ID black iron pipe with 2 tabs welded or brazed to the outside, tabs are 3/8 wide X 1/8 thick and extend 1/2" past the end past the end of the pipe. The tool can be turned with a pipe wrench using a block under the pipe to line it properly. The levers and links are made of mallable iron and can be straightened if not too bad, those little links for the levers cost me $20.00 ea. Was the brass release collar damaged also? Good luck Jake
Dan Cox
09-20-2002 06:08:17
 Re: Re: Re: Re: Super 55 - PTO/Drive Oil seal removal/installation in reply to jake, 09-19-2002 22:04:41
Jake,
Thanks for the info.. I got the seals out last night without any big issue accept for the rear seal on the PTO clutch.. that took forever.. I had to rig a puller with a bolt and plate! Anyway All three of my levers were either broke or badly bent and four of the six links were broke or bent.. I was able to get six used ones for $4 a piece.. I figured for that price I might as well get all six in case I need them later.. The levers were $49 each new, but I got them used for $20 each. The Brass release collar is ok.
I have all my parts coming in today via UPS from Maibach's in Creston, OH. They have a huge inventory of new and used tractors and parts.
Jonathan Rinehardt
09-20-2002 17:15:50
 Re: Re: Re: Re: Re: Super 55 - PTO/Drive Oil seal removal/installation in reply to Dan Cox, 09-20-2002 06:08:17
Dan I was just reading about problem with the pto clutch on your Oliver 55. I also have a 55 split apart replacing the same seals .I dont think the oil leak caused the clutch to come loose.My clutch inner drive had two set screws holding it on the shaft. One on top of the other you might want to try this to help lock it down. Just a suggestion.
Bob
09-20-2002 19:21:06
 Re: Re: Re: Re: Re: Re: Super 55 - PTO/Drive Oil seal removal/installation in reply to Jonathan Rinehardt , 09-20-2002 17:15:50
When working on the rear seal, don't forget to replace the oring on the long power shaft sealing it to the bearing center housing, approx. 1 inch in dia.. Get a parts book and you will see it. Good Luck. Bob
